Fuel line Bomb to change fuel pressure
Pac Brake differences
Piers New HX-50 hybrid turbo "tested"*-
Has anyone noticed any difference in their fuel pressure readings by ONLY changing all the banjo bolts to those sold by Genos?
If so, what did you see?
Higher at idle?
Higher at cruise?
Higher at WFO?
Or, less of a pressure drop between any of the two?
I have a set coming, and just wondering what to expect, if anything.
Thanks, Jim
Jim, I gained a pound at WOT, all other numbers were the same, I have since gone to all new lines with 6an fittings and I can maintain 15 while cruzing at 75 mph and at WOT I now have 12 psi, also my aux tank feeds the L/P as it sits higher , I use the oem tank to transfer to the aux, I consider this to be the best bomb so far.
cheers, Kevin
Pressure change
I installed a set of the Geno banjos and saw no noticable change in pressure readings. I still have stock injectors BUT if the volume of fuel needed at the injector does not exceed the capacity of the pump there would be no pressure drop.
