Engine/Transmission (1998.5 - 2002) Fuel Line Help
Engine/Transmission (1998.5 - 2002) No BUS signal
2nd Gen Non-Engine/Transmission t-steering vs inverted y?
Gents,
Been a hot minute since I had been on here, so I hope I posted in right area. I have had some crappy luck with my mechanical fuel gauge, so I bought a new electric one from Genos; a ISSPRO. Anywho, here is the question. I need to disassemble old gauge; to include the feed line to the diaphram/isolater then pull the wiring and isolater line from the cab. Here is the issue: the line that provides fuel from the LP to the gauge is located on a T fitting that goes to A. the VP and B. to the isolater. I will be needing a right hand elbow fitting to get it back to the VP, as i am going to tap into the top of the fuel canister (another great fix from Genos). What is size of those fittings? I dont want to tear this thing apart and not have the right fitting. I hope my description helps. Thanks in advance.
Regards,
J
