I know there are a few posts on here about this, but nothing specifically for what I'm looking for. I am replumbing my gas fuel system for the diesel swap, and I see that the fuel line is 3/8 into the pump with a 5/16 return.
Is that plenty of fuel (volume) for a 400 - 500hp Cummins, or should I be trying to put in 1/2" supply and 3/8" rtn. The reason I ask is because even if I run 1/2" supply, arent' I still limited to the 3/8" supply inlet at the pump (on the engine?).
Along those lines, have any of you guys running bigger turbos or twins had to change the stock fuel line size(s)? I understand that 1/2" would be plenty, but it would be a hassle to make all the step-up/step-down connections at the sender and the pump - especially if it's not necessary.
