Engine/Transmission (1998.5 - 2002) fuel line size for fuel pressure sender
Engine/Transmission (1998.5 - 2002) 00 wastegate
What size(inside diameter) line should I use to isolate my fuel press sender from the injection pump? I know some people use grease gun hoses but I'm gonna have a hose made up at a hydralic shop for reliabilty.
Thanks
J-
have you looked at a grease gun hose?
Its more than adequate for the job and its less than $5. 00
If you want to spend more there is a tdr member that made up a special hose that will work
RCPilot or something like that
I had some braided fuel line (16") of 5/8 :eek: so I used that and if ya want to mount it locally Grab a "Yard tool " holder from Home depot , Lowes , or similar and the sender fits in perfectly and neatly on the firewall (Autometer anyways) It looks slick as slick and gets chicks too :rolleyes: well maybee not that far but if they saw it I bet ... ... ..... aww nevermind :D
Briar Hopper sells a mechanical fuel pressure hose and gauge that hooks up to the Banjo connection pre-fuel filter or the one near the VP44. I used his hose(an A/C charging hose with 2500psi
+ pressure max)and hooked it to my Westach fuel pressure sending unit on my fender with his Banjo connection.
It's a 5' hose so I did a couple of loops to my sensor. It works great!
Bob
