Fuel Line to Lift pump
newbie
Tires
I upgraded all my fuel lines except the one banjo bolt into the lift pump and wanted to do it too but noticed that there is a steel line going into it and followed it back and don't see where it stops. It seems to turn into rubber and head to the tank. Is there a fitting somewhere under the rubber???
Nope. Its a plastic like hose with a rubber outside cover. That goes to the metal line that leads back to the fuel tank. The return line is the same way.
Always ready to help!
2000 2500 Red Sport quad cab, 4x4, K&N, DDI's, straight piped, boost, pyro and fuel pressure gages, Hot Power Edge, EZ box, race transmission, Barry Grant fuel system, mean looking set of 33. 5" tires, Snap On diamond tool box, Marine Corps window sticker, Semper Fi!
1972 340 Cuda'. Original tripple Black, 340 car w/air. Good clean car, super stock springs, Weld Prostars, shaker hood, strong 340 with a 727/4000 stahl, 4. 56... . Bombs away!
NRA Life Member
My Diesel Page
You can remove the plastic line from the steel line, place a piece of 3/8 rubber line over it, clamp it, and run it up to the lift pump with the proper fittings.
98. 5 3500 QC 4x4, Driftwood/Mist Grey, 5 spd, 3. 54, 19. 5 Alcoa's, Ranchhand bumpers, DeeZee toolbox, "Physcotty Air", TST PowerMax2, VA, 275's, Autometer Gauges, Centerforce clutch, Upgraded fuel lines (JRE and Aeroquip), MagHytec Diff Cover, PacBrake, Cowl Induction Hood
Well, I have tons of braided line and the five fittings that connect the line to the ports on the pump and filter housing. Where does the line change from plastic to metal and what type of fitting is it? Mine is a '98. 5.
Thanks
The supply line comes out of the tank plastic, turns into metal as it runs along the frame rail, and the turns back to plastic wrapped in rubber as the frame rail bends upward right to the left of the transmission under the driver. You can cut it loose and then unhook it from the lift pump. Install your adapter into the lift pump and you hose end fitting on the end of the hose. Hook that up and run the line down to the steel line you just cut the old line off, slip it ove and clamp it down.
Clear as mud.
Thanks Jeff that was exactly what i needed. I was worried I would get into it and end up doing more damage than necessary. #ad
Keith
I upgraded my lines with the braided lines & used one of those compression type fittings. The ones withthe 2 parts that screw together with a ferrule thats snugly fits over the steel line in between the male & female fittings. You,ll have to loosen the line clamps & cut the flared end off first with a small tubing cutter. No leaks so far!!
Ian
2001,2500 q-cab,auto 4x4,4. 10 anti-slip rearend. All options except leather seats. Line-x bed & tool box. Slide-in -removable rack,BFG 295,s ,Fender flares. Westin nerf bars,billet grill & fog inserts. Rancho,9000,s,Isspro gauges,1994 2500 4x4,12 valve,5 speed, bone stock for now.
good eyes Treeman I was gonna suggest the compression fitting instead of the worm clamp or flare type
Earls part number 165006
3/8 comp type with 6an hose end
B
END THE OPPRESSION FREE HVAC NOW
