This may have been thought of or mentioned before, but if so I missed it. I was looking at the injection pump bypass valve and noticed that it uses the same banjo fitting as everywhere else. It is through this fitting that most of the fual returns to the tank. If I use an inline style lift pump that flows 140gph, that means at least 130gph has to go through that tiny restriction on the way back to the tank. Is it going to cause undue stress on the lift pump to have to force that much fuel through that tiny little hole? I am replacing the stock fuel supply lines with -8AN, but obviously I don't want to replace the whole stock return. Should I drill out the banjo fitting to increase flow like some people have done with the supply side banjo bolts?
I would think that this isn't an issue with the way Chads is set up since the regualtor he used has it's own return port. While it does just tee into the stock return, it doesn't have to flow through any necked-down fittings.
