fuel lines
Computer reset?
Trnsfer Pump Problems ??
well my fuel lines are now leaking. . the worst is along the rail under the drivers door... also above that connection at the junction beside the transmission... . my question is this... . is it replaced just from the rail connection back to the fuel filter and there appears to be hard lines on the side of the trans, so the upper pieces from those hard lines to the filter should be replaced also, right? the lower braided lines and the upper rubber lines should all be replaced while i am there??? thanks for the help... . cya
'94 2500 4x4 3:54 auto prime-loc tst #6/230 DiPricol egt/boost
dustoff,
Usually only rubber lines need to be changed.
I would double check your lower leak to confirm it is not actually run off from leak higher up.
Bill Thomas
Missouri Mule - 96 Wht 4X4 ST CC,5 spd, 3. 54, 8 ft bed, 1 ft high cheater boards.
99 Freightliner bl/wht FL60 ISB-5. 9 24v,215 hp,520 tq,6 spd, 3. 59 nsr,16 ft box, 19. 5 tires,Wt/gvw 11,000/23000
[This message has been edited by Missouri Mule (edited 02-04-2001). ]
thanks bill... . good point that i did not consider... thanks again...
