Sounds iffy to me. A fuel "losing" BTUs? That doesn't seem right.
What color do these people say the tank needs to be? Pink?
Ryan
A black tank will absorb heat. Hot fuel has less specific energy per unit than cold fuel. So, if you let your truck sit in the sun all day and significantly warm the fuel, you could theoretically lose some energy.
Oh, wait, you still wouldnt notice because YOU ALREADY HAVE A BLACK TANK!!!! :-laf:-laf
jwgary- you are correct in your assesment. This is exactly why as the fuel heats up the power of the engine will fall off a bit. Remember the injector only knows volume. It does not know density (mass). Therefore less energy is injected per injection cycle and the resulting lower power output.
Regards,
