I removed the fuel module in the tank to replace the fuel sendor. And of course I found the metal slides for the float to be bad and the bottom section of module was not attached to the top. Also the screen on the bottom was ruined. After doing some shopping I elected to purchase the module the NAPA because it was almost half price of Mopar. Well now I have the NAPA one and it is a little different than the one I removed.
The one I removed had metal pickup and return tubes, also the breather was in a seperate hole with nothing hooking to it. Well the new one through NAPA is all plastic the supply and return lines are different but will work and the fuel sendor module is a different style.
Is this an updated model or just not the correct one?
