Archived Fuel plate identification
Archived Help!!! putting engine back in the truck
Archived Need to find shop in south GA to replace head Gasket
I don't know if this is a 911 emergency, but I need some advise. I have a 1997 Ram 3500 with the 12 valve cummins. The truck runs great just a little hot. I can get about 35 pounds of boost, but can easily hit 1200 on the pyro before leaving 4th gear. I got the truck used and most signs point to the fact that the previous owner knew nothing. The only number I can see on the fuel plate is 24242. Other than gauges and a south bend clutch I haven't done anything to this truck, but I don't want to buy an engine. Does this number mean anything? I'm would rather not find out its a "custom grind. " Thanks.
If you can give us a picture it could be identfied. Or-- a detaled discription of it shape.
Welcome to the site.
Definitely seems to be a hp plate on it to hit that PSI and EGT.
But if he disabled the waste gate you could see those PSIs and EGTs. The stock turbo after 28 to 30 psi just makes heat.
Click on Post Reply under the space where you type your message there is a small window that say attachmentes or manage attachments click on it. Then go find it on your computer, when you find it click open then click upload. Make sure your with in the limits of total kg and width and height.
It mite be a little different I'm doing this by memory.
The engine has the boost elbow on it already. I don't think they diabled the waste gate, but I will double check. Thanks for all the help!!!
