I know this topic has been covered quite a bit from all the replies I am getting from searching, but just wanted some input. I installed a fuel pressure gauge yesterday since I have been in question as to whether I am getting normal pressure at higher engine speeds. It turns out that at idle I was around 17 psi and at 2500 rpm not much more (no load). I took apart the overlow valve and checked the spring which was about 7/16 so I got it to a hair over 0. 5 and tried it again. Fuel pressure at idle was about 24 psi and at 2500 rpm it was about 20-22 psi. I took it for a test drive and it seemed like it helped but it is very easy to get the fuel pressure down to almost 0 psi. I should have mentioned before stretching the spring I was only getting about 22-24 psi boost and after stretching I was able to get back to about 30 psi boost. I was going to order an overflow valve tomorrow but I guess I was looking for some input as to whether everyone thinks this will solve the problem. It leaves it a little in question for me since I now know the spring is about where it should be and my fuel pressure is so low. My sig has the information on the truck and I should note that the TST plate is set in the same place as the stock one. No fuel leaks, very slight seeping has started around some hoses but nothing that would cause such low pressure. Any input would be appreciated, thanks in advance.
