My experiance is, if your fuel pump is working good, no fuel restrictions, or sucking air, you should have a minimum of 10 psi wot. prefilter, with no more than 5 psi drop across the filter.
Are these temps, on the flat or pulling hills, if they are while pulling hills and then the temp drops on down hill side or on the flats then they are fine. If they are at that temp on the flats then I would change oil and check for metal.
If lots of metal, might have some bearings going bad.
