I have some questions for you guys with fuel pressure gauges (or anyone who knows). I finally got my gauge working with a new sender. I used a needle valve and 3 feet of 1/4" hose and mounted the sender remotely this time so I will now see how long it lasts.
My question is: is it normal for the fuel pressure to bleed off just a few minutes after shut down or should it stay pressured all the time? Seems like I remember Illflem saying his did not bleed off. Mine bleeds off pretty quick. Could this mean I have a bad overflow valve? My fuel pressure was 16 PSI at idle and 20 PSI no load 2,000 RPMs. I then changed my fuel filter at just under 6,000 miles and the fuel pressure went up to 22 at idle and about 26 no load 2,000 RPMs. I also get more lift pump "tick" than my buddies. Maybe I need a pump? Any thougths? Thanks!! Truck has 73,900...
