fuel pressure, boost gauges
Canadian Service Manual
C
Cummins website
Where is everybody installing the boost gauge fitting and fuel pressure gauge fitting on the CR motor?
I removed the intake elbow, drilled and tapped it 1/8 npt to accept the fitting. trace the steel pipe from the filter head to the pump and installed a tapped banjo bolt (note: fuel pressure is around 8 to 10 psi )
