rjrkihap
I’ve been following the fuel pressure threads (as I too have recently lost my vp44 and lift pump) and am a bit confused. Cummins and Dodge (Bosch also) state that as long as your lift pump is putting out 5psi your vp44 is just fine. In fact, they will not warranty the pump until THEY can verify less than 5psi. However, I have also read that as soon as you drop under 10psi your vp44 is in danger of being damaged. I’ve also read that those who have had the in-tank lift pump retrofit are seeing pressures under 10 right after the install with Dodge commenting that flow is what’s important and not pressure.
My question is who’s right? If the under 10psi rule is correct, then a lot of us will end up replacing our lift pumps ourselves even if it’s still under warranty.
Thanks
Ron
Thanks
Ron
