I'm sure this is the case, but my fuel pressure numbers increase as the engine warms. Anyone else?
When engine is cold ( either sat over night or actuall temps outside are cold) I get 12. 2 at idle after the grid heaters run their cycle. After engine runs for about 10 minutes that increases to anywhere between 13. 0 and 14. 0 at idle.
If I park and the restart a while later the pressures stay up in the 13's at idle.
The cruising pressures have about the same swing with the temps.
I dont know what WOT is cold as I dont step on it hard until the thermostat has opened atleast once.
ANy thoughts. I think it has to do with the higher the temp higher the pressure rule from physics ( I think thats bernoullies law?)
Also anyone else see FP drop acouple of tenths when the grid heater cycle. Mine does but comes right back up when they cycle off.
Thanks
J-
Thanks
J-
