I know all the specs for fuel pressure at an idle, under power, ect... But the specs don't mention anything about temperature and my fuel pressure is decidedly different depending on the temperature. Currently I'm starting it up here in the morning around 40 degrees outside and it idles above 30 psi... last summer when I was going through Vegas and it was 100 degrees outside I was lucky if it was idling with 15 psi. So is there a specific temperature at which the fuel pressure is supposed to be within spec??
In my mind the temperature really shouldn't make a difference as liquids are not really compressible. But the temperature obviously has an impact here. As the truck warms up the fuel pressure will drop a little but the biggest impact seems to be the ambient air temp... At least from my casual observations.
