A lot of guys have been asking about my fuel pressure gauge installation lately so I thought I'd bring it back up top and do some updating of the information depending on model of truck,etc. When I installed mine (June of this year) I wanted to be able monitor my lift pump pressures and also be able to monitor the status of my fuel filter. After looking around I decided to go with a Stewart Warner gauge with dual senders.
I bought the gauge and sender's through XK's Unlimited - http://www.xks.com/ - a jaguar place!! They had the best prices I could find. I bought the track force gauge because it matched the closest to my DiPricol boost and pyro - the page they are on is here http://www.xks.com/SW%20Pages/swgaug11.html . The gauge I bought is the SW-82868-P which is a 2 1/16" 0-16 psi electric gauge with a black bezel. The sender's were the 82504-F . They also have many other options on there for other style gauges.
To mount the sender's I made a small custom bracket out of aluminum that's sandwiched between two existing brackets under the hood (see first picture). I put slots in the bracket and ran hose clamps through them to attach the sender's - they have to be ground. I originally had the sender's plumbed into my prime loc (pic 2) but have now moved them to the test ports in the top of the fuel filter head (pic 3). You just use 1/8" npt to barb fitting adapters to attach the lines. That applies to '98. 5 & '99 24v trucks, for the '00+ guys you have a schraeder valve on one of the banjo bolts at the fuel filter head and another at the banjo bolt at the injection pump. By my understanding you'll need to use a 4an fitting to attach to it and will need to removed the valve core out of the fitting first.
Then all you have to do is run 2 18 gauge wire's into the cab and run them to a switch and then to the gauge. I put my switch in a small project box and attached it to the dash and then attached the gauge to it with one of Geno's donut mounts (last pictures). The gauge also needs 12v and has a light which I just fed to my other gauges.
Total cost for my setup was around $80 for the gauge and senders, $5 for the aluminum to make the bracket, $10 for the gauge mount, and about $3 for the fuel line, hose barbs, hose clamps, wire. I have replaced two lift pumps on my truck, the last one after only 6,000 miles on it! WIth a brand new lift pump I see 13-14 psi at idle, 12-13 psi driving down the road and a low of 10 psi under extended WOT just for comparison's sake. I personally recommend that anyone with an ISB install a fuel pressure gauge if for nothing else other than peace of mind!
-Steve St. Laurent - President of the Great Lakes TDR
'98 QC LB (CMNSPWR), 4x4, ISB, 5sp, 4. 10 LSD, TST Powermax, 275hp RV injectors, SW fuel pressure gauge, BD exhaust brake, Isspro turbo temp monitor, front Draw-Tite receiver, rear Draw-Tite class V receiver, BFG 285/75R16 AT KO's, (all the common stuff clipped)
[This message has been edited by Steve St. Laurent (edited 12-07-2000). ]
