rotohead
Steve,
I've installed a similar system but having trouble holding prime on either side. Did you use, or consider using the 'one way valves' as shown in the service manual on the fuel filter? Maybe I'm using too small a hose clamp? Where would I find a one-way valve like that? Any help appreciated because I won't drive comfortably after 45k and not be able to keep an eye on that lift pump.
'98. 5 2500 QC ISB 4x4 SLT, Auto DTT TC & VB, JRE 4" exhaust w/5"Tip, DD II's w/Module&Elbow, VA box, Rancho 9000's w/in cab adjust, Mag-Hytec trans&diff covers, Jacobs E-Brake w/BD autoloc, trans temp, boost & EGT gauges, 2Low Kit, Air Horns, Catz MSX, Drawtite Front Hitch, Brite Box, Steel Horse Billet Grilles, AirBullDog hood induction system, Brandon's stainless steel fuel lines, Intake heater system saver
