Wayne,
If you are already using the diaphragm design then "no" going to Vulcan's set-up will not help.
Vulcan Performance Home Page
Is where Eric can be contacted. Also 866-466-1043
The fluid you choose on the backside of the isolation unit is not critical. I do not know how you are feeding the isolator from the input from the VP-44. I assume you have selected a pick-off point with proper fittings. Now... the thing that is important is the type of line you are feeding the diaphragm with. In general the "grease-gun" hose arraingment is a
poor choice. Selecting standard rubber hose is the best. Of course, select a hose that is fuel compatable. I'm using standard 3/16" (Goodyear) line and the length takes me from the VP-44 input, back to the firewall on the drivers side where the diaphragm isolator is mounted. Keep in mind we are only working at sub 30Lbs PSI here. 20,000 PSI burst test grease gun line is not required!
The reason for the standard rubber line compared to the "grease gun" line is the expansion/contraction coefficient of the rubber line. In small terms "it is the additional snubbing" or shall we say the hose will expand and contract at a level that is equal to the oscillations of the "back-pulses" of the VP-44's sipping action. It will reach a point of equalization and provide a nice additional capacitance for your isolators diaphragm to reach an even equilibrium and provide a nice smooth hydraulic force to activate your gage's needle movement.
Grease gun lines are "hard lines" and have little dampening effect to help your diaphragm stop oscillating at the sypathetic resonance of the VP-44.
Good paint stores ( for exact paint tinting) and perhaps a local Veterinarian will have
the nice large hypodermic syringes to allow a precision enema feed of your capillary line during the prime up procedure. It is technique and finesse that counts here... don't do the Homer Simpson thing.
I take PSI readings on closed high pressure liquid filled systems for a living. This trick at 15 PSI is a very simple thing... . just take it easy, use the correct components and don't sweat a few small bubbles it won't make a hill of beans of difference at this level.
William
