I reciently Installed a Fuel Pressure Gauge on my 02 and am trying to figure out if it is working right or if it was worth getting. On start up it jumps to 12 psi then after driving it drops to 5 psi. When driving around town it is anywhere from 1-2 psi and 0 at WOT. I spoke with a man at the local diesel shop and he claims the vp44 is using all the pressure so that is why it is not reading when you are under power. Is this true? If i do have a lift pump problem will the vulcan big line kit help this?
thanks
joe
2002 Extended cab, short bed, 2500, 5 speed, Strait pipe, BHAF, Fuel Pressure, Exhaust temp, Boost, no silencer ring.
thanks
joe
