HELP!!!!
I finally finished the installation of my Westech Fuel Pressure Gauge from Genos. Bled the line going to the sender since it is mounted remote, and fired her up. First thing I see is that the needle starts to climb before I bump the starter and when she is running..... It's pegged at 15 psi. WOW!
Is my lift pump on steroids??
This is a replacement lift pump after my original was leaking fuel my first week of owning the truck. It is a '99. I used the factory grounding stud under the dash near the E-brake lever for both the sender and gauge ground, so it should be properly grounded. Any ideas???
Thanks!!!!
Thanks!!!!
