I drive a 2004. 5, the one with the weak fuel transfer pump. Have 80,000 mi so decided I need a guage so bought BD LED Low Fuel Pressure Indicator from Geno's. It is suppose to light when the fuel pressure drops to 5 psi. After installing it flickered on and off whenever traveling above an idle. I installed a new 'original equipment pump', from Geno's, thinking the pump was getting weak. The indicator flickers almost as much with the new pump. Anyone else experienced this?
Does the pressure normally vary this much? Do I have a bad pressure indicator?
Thanks
Thanks
