Are you saying the isolator failed due to fuel additives? Was it an ISSPRO isolator? If so, did you send it back?
Maybe I should've clarified. I was speaking of isolators in general, and not necessarily ISSPRO.
I ordered a bunch of DiPricol Optix series gauges from Diesel Manor, and also purchased the fuel isolator as recommended. I'm not sure what brand it was... it was recommended as a safety feature, so I bought it.
It wasn't long after I installed it that my fuel pressure gauge became somewhat erratic, and then showed "0" pressure. I assumed it was the Walbro lift pump gone bad, and so I ordered a new one.
Meanwhile, I hooked up a manual pressure gauge under the hood, before the isolator, and pressure indicated the normal 18 psi. Thus, I determined the problem was not with the lift pump, but was with the gauge. I left things like this for almost a year. One day, I decided to bypass the isolator just to see what would happen. The DiPricol fuel gauge immediately started working, and has been fine for the last 4 months. I am not using an isolator or a snubber, and I get no needle fluttering on the gauge.
The isolator originally failed soon after the introduction of the new '07 ULSD fuel, and I thought that was the cause. However, several other people who also are using an isolator from DieselManor have not had problems, even with the new fuel. Thus, the only thing I could come up with, is the additives I was using at the time contributed to the failure.
Up to the point of failure, I religiously used a mixture of Power Service and Marvel Mystery Oil as fuel additives. However, after reading the report that came out on lubricity of different additives, I immediately ceased using both of these products. FWIW, I now use Schaeffer's diesel treat, and also try to run around 5 - 10% bio.
--Eric
