Engine/Transmission (1998.5 - 2002) Fuel pressure gauge
Engine/Transmission (1994 - 1998) Bigger lift pump?
2nd Gen Non-Engine/Transmission VIN Summary Report
WHo is running their fuel pressure gauge without an Isolater? ANY problems doing it this way? My concern is the potential for spilled fuel in the cab.
We took the isolator off of mine. The gauge wasn't accurate. We replaced it with a brass needle valve in case there are any problems. It works great. I could take some pictures if you would like. Jeff
I put needle valves on my fuel psi sensors to keep the pump from beating the sensors to death (which it did until I needle valved them).
Bob Weis
The needle valve is like the one on your refridgerator water line, just a little brass needle valve you get at Home Depot.
To get a gauge to read pressure you only have to open it a very very very tiny amount. Which also if something drastic happens on the gauge side only a very small amount of fuel gets through and you can shut it off using the same needle valve.
I use it to keep pump oscillations from killing my sensors. I turn it all but off and the pulses from the pump gets smoothed out before it reaches the sensor because the needle valve is set to such a small amount of "open" that the pulses are diminished so much they do not have much of an effect.
Bob Weis
