2nd Gen Non-Engine/Transmission Fuel pressure gauge
Engine/Transmission (1994 - 1998) HELP! Fuel Shutoff selenoid
2nd Gen Non-Engine/Transmission Smarty fuel saver test
Im going it install a fuel pressure gauge on my 01 H. O. and wanted your opinion on which to buy. I don't plan on adding any power adders... well maybe later on. :-laf The westech gauge looks pretty easy to install w/elect. sending unit but I kinda like the way the isspro looks. What psi gauge should it be? 16 or 30? Any input is appreciated.
I went with Westach because I went with the whole stack... trans temp, fuel press, boost/EGT. There have been some sending unit failures reported but I've had no problems in three years. I would rather have a sending unit fail than have a gauge fail and leak fluid, anti freese or diesel or whatever in the cab. I also put a snubber in to protect the sending unit from pulses from the pump.
Mike
I went with the Isspro white back from Geno's. I just told them to include everything else I'd need for hookup on an 01 and to include the rubber donut for mounting. THey included everything I needed and the rubber donut mounted under the dash just to the right of the gear shift really worked awesome.
