15 days ago +- I installed Westach FP Gauge. Upon completion of FP Gauge I noticed low FP.
Took truck to dealer for new Lift Pump & it was covered under the Cummins Warranty. This
morning on the way to work I noticed my FP was running around 15-16 PSI, a little higher
than normal for cruising... . Typically around 13 PSI+-.
After work today got in truck & truck was running like starved for fuel... Looked at gauge
& had 1-3 PSI. Limped truck home & went to the dealer & he said likelihood of LP going
bad in 15 days after being replaced with new model LP was low. Took truck home & replaced
fuel filter (looked OK) & now while trying to get my lift pump to cycle I get nothing. I
can't even get the lift pump to cycle... . Sounds like lift pump to me I guess!
Has anyone had this problem before? Is there a fuse for the lift pump?
Planned on taking my truck into Dynamite Diesel Technology tomorrow to get dyno ed, but
not looking Good at this point.
FP gauge is mounted on the discharge side of the filter.
Thanks, Clay
Thanks, Clay
