Engine/Transmission (1998.5 - 2002) Fuel pressure guage - drill hole in firewall??
Engine/Transmission (1998.5 - 2002) Egt's
Engine/Transmission (1994 - 1998) Power Upgrades
Tomorrow I'll be receiving an Isspro mechanical fuel pressure guage and all other necessary parts from Genos Garage to install in my 01. I took a quick look at the firewall and don't see any existing locations to run a fuel line. Am I correct in assuming that I'll have to drill a hole in the firewall? I plan to hang the guage at the bottom of the dash.
Ive put alot of stuff through the grommet that the parking brake cable runs through. Also poked through stuff around the wire bundle. Both are on the firewall near the driver side fender and can also be seen and felt under the dash.
I used a chunk of coat hanger and pluged the end of the 1/8" hose and forced it through a grommet. It worked well enough that I was able to do the same for the boost and pyro wires.
Ben
There is one thing that is nice having a slushbox. Have a big grommet to stick stuff through (where the clutch assembly goes through).
