Augustus, Autometer Ultra lite mechanical gauge ??? Or is it the one with the electric sender ??? When you say it does a complete 360 then goes to 15 psi's... do you mean that it is actually spinning past 15 psi's and then all the way around back to 15 psi's ??? Or are you saying that it just goes right from 0-15 psi's when started at idle ??? I'm guessing the second one here as I doubt the gauge needle could get past the pin that it rests on when at 0. If it's going to 15 psi's at idle, all is well and you have good psi's. Can you drag the psi's down when you accelerate ??? You should be able to drag the FP down to 13-14 when pressing the go pedal at idle, more when moving of course. Hope this helps !!!
By the way, it's not really pegged at 15 psi's... I have had mine spun past 15 psi's, all the way to the 7 o'clock position on the gauge while adjusting the Mallory pump.
Scott W.
