fp
ty584, not to take away from big's pride in his gauges, but... . there are lots of choices. i like my Isspro
ev's. SPA, westach, Dakota Digital, and Nordskog, autometer, and i think even stewart warner make the gauges, to mention a few. the fp gauge is mechanical, ie, had to run a line into the cab. isolators are available which will use a fluid such as antifreeze in the cab, so no fuel in the line in the cab. with a mechanical gauge, i was able to connect at the schrader valve on the VP44 and check the pressure at the inlet to the VP without getting fluctuations or destroying the gauge. drilled and tapped banjo bolts are available--i got mine from geno's garage. while i was at it, i replaced all five with bigger bore banjos.
last, briarhopper (TDR member) has put together a "test kit" which is quite reasonable in cost, if you don't want a permanent gauge mounted.
you may want to consider a brand which will have at least an EGT gauge to match. it helps to see the post turbo EGT, to time shut down after the turbo is cooled adequately to prevent "coking" of the oil. boost is fun to watch, but less important to monitor than FP and EGT.
FP gauge should have at least 20 PSI capability.
