ROFLMAO
You guys. :-laf Ok where do I start???
I think you guys are thinking like, way to hard on this one ... ... ..... "Can't see the forrest because all these trees are in the way" kinda thing.
I don't want to get the PM from our good Pastor cause I was recommending who to buy part(s) from and who has the best prices sorta thing. There is a very fine line there. So what to do??????
OK... ... You look in the cataloge we get w/our TDR magazine. Then look in the area of gauges. Then you order that 16 OR 30 psi fuel gauge which includes the sending unit for like $68. 00 (I don't have the cataloge before me so cant give part number or exact price, sorry) While you have this particular organization on the phone, you say... ... . " Give me the pipe tap banjo fitting for the 24 valve trucks and throw in a package of them little seals along with it pleez".
When the brown truck pulls up in your drive-way,,,,,,, sign for said package. Remove the contents. Open the trucks hood and remove the upper banjo fitting. It has the bleeder screw threaded into the banjo bolt head. Install two new seals onto the new pipe tap banjo and secure it. Your new gauge will have a sending unit that is placed into this new banjo. It's electric, so you will have to hard wire it.
With our trucks instock form, a 16 psi gauge will work ok. You will see somewheres about 10 psi to four on the low side. If you are bgilbert and installing a super tuned VE your bud has set up for you,,,,, then you'll soon find a pusher pump is gonna be in the works so I'd opt for the 30 psi unit
hint hint
All in all you will have about $100 invested shipping included. Where are you guys getting this kit idea from
There is a gauge company that starts with the letter "I" that does have a fuel psi gauge. It, however, has proven to be big $$$ and unreliable. They say they are working on bringing out a new model to replace the unit of past.
100 psi fuel gauge!!!??? WOW,,,,,,,,,,, What would you install this on???????????????
John Force may have one but you won't
Scott
