I will be installing an electric fuel pressure gauge, running the hose from the banjo bolt post filter on top of the fuel canister ('99) to the sending unit. I have read posts that air should be left in the hose. I would think that if air is in there it will eventually get into the pump, etc. and I would have a "no-go" situation. After all when I change the fuel filter, I bleed the air from the test port so it will start. Wouldn't it be better to have that hose full of fuel to the sender or am I am just thinking too much?
Thanks in advance for the help.
