I installed a set of 370 injectors about 6 months ago and have had problems ever since. The truck lost a bunch of off idle power and stumbles under 1500 rpm. Before i installed the injectors I could start off in 1st gear with out touching the throttle but now I have to feather the throttle on take off or the truck dies. I bumped up the idle to around 900 rpm and it made no difference. The engine also idles really rough, I mean the whole truck shakes! Today I tried breaking loose one injector at a time to see if the idle dropped. When I broke loose the # 1 & 6 injectors there was no drop in idle but #'s 2-6 all dropped the idle when broken loose. Does this mean I got two bad injectors? Or could there be other problems I should check for? The truck really seems to scream once over 1500rpm's and the boost comes on. I also checked the fuel pressure today with the TST adapter and my boost guage. The fuel pressure goes right up to about 46 psi and stays right around there no matter what the rpm. The guage is very smooth, no pulses like i have heard of. I tried to pinch off the ruturn fuel line and the pressure goes to over 55psi. The fuel filter is fairly new, as far as I can tell no fuel lines are kinked. Any ideas? Sorry about the book here, i just wanted to explain the problems as well as I could.
Thanks,
Bill
Thanks,
Bill
