Finally got around to installing a fuel pressure gauge on my '01 CTD. Truck has been running fine, plenty of power while towing, smooth idle no signs of any problems. Have been monitoring EGT, Turbo Boost and transmission Temps via set of Isspro gauges that were installed shortly after purchasing the truck.
So... . Thought everything was fine until I added the Fuel P gauge! The gauge is an Isspro EV2, electric pressure gauge, connected to the shraeder valve. When the truck is at idle the gauge reads 8 - 9 psi. I checked the Factory Manual and it stated that the fuel pressure should be 10 psi.
My question is... . Do I worry about this or is it within reasonable parameters?
Truck has 90k miles on it and is stock except fot exhaust and Edge set at Level 2.
