Okay, so I finished my new fuel pressure gauge install, and everything is fine on the road. All the PSIs are good, etc, etc.
There is a really weird behavior, however, right after I start up the engine. I go from "off" to "on", and the gauge jumps to 15, and then slowly falls back to 0.
I was assuming that the VP44 is returning fuel, but that the lift pump isn't on yet. Is that correct?
Then, after I start, it hovers around 5psi, both pre and post filter. I was really freaked out, so I checked the senders, but nothing is leaking. Could this be a grounding issue? I know the system cycles the fuel heater, etc, and that draw a lot of current (I can see the changes it in my headlights).
The other thought I had was that I had air in my sender's hoses, even though I did my best to make sure the air was out.
Once I'm on the road, it comes up to the right PSI levels and stays that way the rest of the time.
Am I seeing a freaky lift pump, air in the lines, or electrical trickery? (I can check the ground... )
