I have a di pricol fuel pressure gauge and when i start it up some mornings it will read 7-7. 5 psi. Then there are mornings that i start it up and it will read 5. 5-6 psi and sometimes almost into the red on the gauge. This all occurs at an idle. Is this a problem with the gauge, isolator or is this a lift pump problem. The only mod that is on the truck now is a powermax cr. Do I need to replace this with a pusher pump to correct this problem? I'm confused here of what is going on here with the pressure.
