Just installed an Auotometer electric fuel pressure gauge and everything was reading normal, 15psi at idle and 12 - 13psi at a 65mph cruise and 10psi at WOT. On a 40 mile trip the gauge decided to wave at me a little bit and now at cruise it reads a steady 8 psi and as soon as boost is needed (hills and such) it drops to 5psi at 20+psi of boost.
I have totally rebuilt my fuel system: -8an bulkhead at the bottom of the tank, -8an line to suction side of Carter 4601 fuel pump mounted on the frame, then -6an line all the way through the filter housing, then -6an line int the injection pump. Fuel pressure sending unit is in line between the filter housing and injection pump. This system is a month old.
Mods to date is MBRP 4", Edge EZ, BHAF, and the fuel system mentioned above.
Ideas or tests I can do? Oh, there is no codes in the PCM.
Thanks,
Sean
Thanks,
Sean
