I have 54K miles on my truck. The fuel pressure seems to be easily "zeroed" out when the weather gets in the lower 30's. Is this normal? I have seen this on fuel from many different stations. Changing the filter seems to help for about 100 miles then it does it again... 15 psi at idle and at moderate speeds thru 3rd gear, then in 4th and 5th when I get the RPM to about 1750 - it goes to 0 and below almost instantly when I try to accelerate. Shoud I keep replacing the filter? Go ahead and replace the lift pump? If so, with a factory pump or other? Is this normally under warranty?
