here's the situation:
when its cold(engine) and start it the fuel pressure is at about 15-16psi (i have a aux pump and factory). but as i drive, with the heat we have been having the fuel pressure increases. more in stop and go where the heat is higher under the hood. ill see 22-28 psi on the guage. its a stewart warner guage with a isolator, fuel to antifreeze. then with the guage reading 22-28psi, i hop back on the freeway and my fuel pressure slowly falls back to 15-16psi.
any ideas? ive taken the gas cap off while running at the high fuel pressure and no difference.
the fuel guage is tapped on the filter housing after the filter.
i have heard of a pressure relief velve on the side of the vp, could that be it?
truck has 130,000miles
want to get it fixed before i head to south carolina for vacation.
