Engine/Transmission (1998.5 - 2002) Fuel Pressure Question
When I start up my truck, I'm getting 13-14 psi but after I start moving and get on the go pedal really good for the first time, it will drop to between 5-8 psi and bounce around everywhere. Is this the first signs of a LP going out? I did the Vulcan big line kit and the relocation kit a month and a half ago and it didn't start doing this until I started into a 500 mile drive. I do have a very slight seep that is coming from a FP port on one of the 90 degree fittings. The seeping fitting is pre-filter and my FP readings are coming from the fitting that goes into the VP.
Thanks for any help,
Ben
the stock style LP's stink, not reliable
up grade or carry a spare ,if the LP pushes less than 5psi to the 44 you'll be buying a new VP.
I had the same problem, unplugged the electric connectors & sprayed with contact cleaner, plugged back in. Fuel pressure would not drop below 8 PSI.
Randy
