A question prompted by the thread in the Product/Assessories forum concerning fuel delivery and Prim-Loc.
My Dodge serviec manual says that the lift pump supplies 3-5 psi to the injector pump.
The maximum drop across the fuel filter can be 3 psi.
However, in the aforemention thread, John states that 12v supply should be in the vicinity of 28 psi.
And Dave Fritz's info on the 1992 Ram Diesel Engine Specs says that the fuel pressure should be 18-24 at idle, 28-36 with no load which is in the same ballpark as John's.
Would someone help me understand how to get from the 3-5 psi in the service manual to the higher pressures noted elsewhere?
thanks..... gary
'92 W250 LE 4x4, NV4500 5spd, Borgeson steering shaft, PrimeLoc
thanks..... gary
