The lift pump has been relocated to the fuel tank & then the VP44 was replaced after 2 successive 0916 codes. After recently installing a Westach fuel pressure gauge & then taking the truck on a short trip I am seeing the following fuel pressures. 7 1/2 psi at idle, 5 psi at 60mph on a level road & about 2-3 psi at 70 mph & about 2200rpm up a long uphill grade while pulling a small enclosed trailer with about a 2500# load. I would be afraid to try WOT because it would probably suck the fuel pressure down to zero. The truck is stock & out of warranty. From what I have been reading on this sight it sounds like these pressures are low.
Any Suggestions????
When I questioned the dealer about the fuel pressure a while back they said that the pump is putting out the proper flow.
Thanks in advance for any help provided.
Any Suggestions????
