So what do you suspect is the culprit??
I have a 3/8" x 2' run of SS braided hose tee'd off the VP44 to the FP isolator, and from there it sends antifreeze into the cab that connects to the Isspro EV mechanial gauge. Pretty standard right??
Readings are fine until I hit the desert, or on hot days when the underhood temps rise, then the gauge starts gradually rising from the 13. 5 norm, up to 20 sometimes. . Last weekend it actually climbed and pegged the gauge at 30!! It also stays around 8psi after shutting the truck down, and creeps down to 0 after awhile. .
For history. . Ive changed the gauge itself, have all new fuel lines, new upgraded fass motor, block, return spring and ball. This has been happenng for about 5 yrs, and after changing everything but the ss hose, and isolator the problem continues. . Also verified normal pressure at the fass by installing a temp gauge there. . It doesnt move off 14 psi.
Guess its either a heat sensitive isolator, or air on the supply to it, or in the antifreeze line. . Just wondering if anyone knows from thier experience. .
Tia for helping with this pia.
