What fuel pressure is the norm? I have a stock 95 2500. There are no performance aftermarket parts on the truck and no adjustments in this area have been made. In the last two weeks I have replaced the entire fuel delivery system.
From the tank to the engine, these items are new:
All new lines are 3/8" and rubber is marine grade. I also removed the original fuel filter and replaced it with a remote filter.
The pressure gauge reads 20# idle. When accelerating from a stop, it will drop to around 13-14#. When downshifting to come to stop, it will climb to 25# briefly and then drop to 20# when stopped.
Does the 13-14# sound right? I thought I read somewhere it should operate in the 20-25# range?
I appreciate any help in this area. I really do not want to waste my IP due to low fuel pressure.
Michael
- Draw straw
- rubber to hard line
- hard line
- rubber to heater assembly
- removed heater element from assembly
- 90 rubber to lift pump
- Lift Pump
- rubber to IP
- IssoPro fuel pressure guage, with Tork Tek snubber on IP inlet
- Tork Tek Over Flow Valve
Michael
