Competition Fuel Pressure Regulators.
Competition CO2 spray intercooler?
Competition NADM Bakersfield, CA 2-23
I am looking for info on good stand alone fuel pressure regulator. I have a FASS 95 GPM pump that I want to put on one of my 1st gens with a VE pump. It will have a 14 MM head and rotor. I understand that too much inlet pressure along with the internal vane pump can push the shaft seal out. I want to have "just enough" pressure with plenty of volume when needed. So any and all suggestions are welcome.
Any Aeromotive bypass style regulator will work for you. If you want a stabil reliable pressure then bypass is the only way to go. I have used Aeromotives and they are good quality but there are many brands available.
Fass
I think the FASS comes with one of two internal fuel regulators. (You get to pick higher or lower pressure) If you call them with your SN they can tell you what it is and maybe save you the expense and effort. It may already have what you want.
