Fuel Pressure Sender Mount
Need Holset/Cummons part#
Noise Reduction
A month or two ago someone posted a picture of a bracket that they made to mount thier fuel pressure senders under the brake booster. Does anyone still have a link to that picture?
Kevin
I used an existing bracket
I pulled the bracket off the master cylinder that holds the hydraulic assist lines, and drilled it for the 2" U-bolt I used to hold the sender. Then, I purchased a 1/8" NPT female ell and a male with a female swivel nut fitting from my local aeroquip dealer for about $4. 00 total. This lets me remove the hose from the sender without having to spin the sender.
If you would like a picture, I will try to post it in my reader's rig gallery (can't get into it right now). Otherwise, PM me and I can e-mail it to you.
