Engine/Transmission (1994 - 1998) fuel pressure service port?
Where is the best place to hook up a fuel pressure gauge to see if the lift pump is working correctly...
Thanks
erik
pictures will help :)
You will need to remove a banjo bolt and install an adapter at the injection pump,or remove,drill and tap.
Bob
Eric It looks like maybe you would have been better off to have just bought Joes truck. ;)
You can get the adapter from Miller tools.
Bob
Thanks for the info Bob. See you at Rattlin Rams Fest... Well the body work was unacceptable on Joes and I felt it was a little too much truck to start out with. Rather learn as i go! Less than half the price too!
Erik
