Well since nobody's given this a crack, Ron, what kind of pressure is your FASS supplying your P-pump? I heard it needs at least 25psi at idle and more with throttle?? I would believe you'd be fine with a 2nd gen piston pump, since you have a p-pumped engine. Mechanical lift pumps are much more reliable than electric any day of the week. As far as a hollow cylinder between the LP and inj pump, you'd have to figure out how to get the supply lines fabbed. I don't know if this would help or not. All I can tell you from my 'low pressure' piston lift pump is at idle the FP is lower than FP with moderate throttle, the FP actually increases some with throttle. Which its supposed to do, its driven by the camshaft, and as rpm's increase, it drives the plunger in the lift pump faster, it pumps more fuel- that is if it can keep up with the demand for the fuel. A dead mechanical LP may give FP at idle but as soon as rpm's go up, FP drops quickly. I would think a p-pumped motor would require a piston lift pump since it requires much more fuel pressure. I would hate to see a guy swap a p-pump on a VE powered motor, and try to run with the diapraghm LP. I guess anymore info on 2nd gen LP's you probly get more exposure in that forum. Good luck with whatever route you chose. BTw you outta get some good $$ for that FASS pump.
