Fuel pressure drops to 3 or 4 psi sometimes lower. Then if I shut the truck off and restart it brings it back up. It may be fine for a few mile then it drops again. Sometimes I can drive all day and it is fine. I had replaced the fuel filter and I put another fuel lift pump in. Did I get a bad lift pump or is something else wrong? The truck runs fine even with the low fuel pressure readings. I was reading these pressures with a westach guage and now I am reading the same pressures with the pressure guage in the Edge Juice Attitude.
