LP fun...
Hi Cory,
My take is that your LP is out its way out... had the same condition. My symptoms were (all numbers are post filter readings):
1. startup: solid 13-14psi
2. idle: needle would jump from 7 - 13 psi
3. upon acceleration, would always get 13psi
Only noticed AFTER installing FP guage (of course... ).
After reading threads on LP pressures, all would report that as the throttle is applied, LP pressure would droop (I didnt see any of this but did have the jumping needle). Things got progressively worse over the course of two weeks at which point the min pressure got around 5 PSI and continued the jumping back to 13psi.
At this point, I dumped the $150 and replaced the LP. Now I get a constant 13 psi at startup and idle. Things ease down as low as 10psi at full throttle. Just hope that I didnt do any bad things to my VP44 in the progress but only time will tell...
Rgds,
Ralph-
